Tool Change issue on Morbidelli Author X5
Results 1 to 2 of 2
Thread: Tool Change issue on Morbidelli Author X5
    Default Tool Change issue on Morbidelli Author X5
    Hello
    We have an issue with our Morbidelli Author X5. We purchased it and due to COVID, the install technicians couldn't make it to our location so we took it upon ourselves to setup the machine.
    Everything is working now except that it doesn't want to perform a tool change. The spindle gets into position but the magazine never advances to grab the HSK. It just hangs there and panelmac says it's waiting for the electrospindle. M152-153 in MDI work so we know the magazine is able to advance and move back.
    In F11, it says that tool E3 is mounted on the spindle, so we manually loaded that tool in the spindle. Still nothing. We setup one other tool in position 2 and left the rest of the spots empty.
    Y relays were moved, so maybe that's the issue? If so, how do we correctly position the Y relays? On the magazine side, there is 2 relay stops, one short and one long one. The short one is for the end relay creating the alarm if activated. The long one, i'm not sure what it does exactly.
    Any help appreciated. Thanks a lot
    Member coc9's Avatar
    Jul 2018
    Default Re: Tool Change issue on Morbidelli Author X5
    1. When you manually insert the tool into the spindle does it show in xilog software that its inside the spindle ?
    2. Do you click on the update button after inserting the tool manually ?
    3. How does it exactly says that its waiting for the electrospindle ?
