Need Help! Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
Results 1 to 2 of 2
Thread: Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
    Default Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
    Hello,
    i put a scheme of what i want to do :
    Masterwood Retrofit-new_config_cn6_retrofit-jpg
    I bougth a piece of card (Z80, CPU683 68EC020 PLC Tecnos system and input / output) for upgrade my cnc Master Project 323 who's working correctely with his old system under Dos ... but not very easy to use
    These cards was working into a Masterwood Project 309 retrofitted
    I replace old card (68000 named 681) by 683
    and Z80 Si_89 by Si_96
    I wonder if someone could help me to introduce good parameter to make it working ?
    With some photos of retrofit of the Masterwood :
    this new CPU3-2M CPU68EC020-2003-01 (31SFC104640) card
    Masterwood Retrofit-carte-cpu3-2m-68e020-jpg
    will replace the older CPU1 (68000) KTC91
    new Masterwood Retrofit-carte-cpu1-68000-ktc91-jpg old
    The old I/O cards (ACCTC90/02) will be replaced by new I/O cards 61SFA300101 (ASSI_CC_2007_01)
    Masterwood Retrofit-carte-es-old-jpg Masterwood Retrofit-carte-es-cavaliers-jpg
    The communication interface Si2.5 is replaced too by SFS10150 SI_96_01 (31SFS101460)
    Masterwood Retrofit-carte-si2-5-jpg Masterwood Retrofit-carte-si4-20-10150-rack-jpg Masterwood Retrofit-carte-si4-20-10150-composants-jpg
    and RamDisk Card is suppressed because no need anymore
    Masterwood Retrofit-carte-ramdisk-jpg
    the software MasterWork drive everything
    To be followed,
    Regards, GLP
    Default Re: Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)
    Hello,
    some pictures of what I want to do
    is there anybody in the place who knows Tecnos controller ?
    specialist of Masterwork parameters ?
    Thanks, bye.Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-img_20190522_171300-jpgMasterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-cn6-retrofit-jpgMasterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-config-io-masterwood-project-323-running-jpg
    Attached Thumbnails Attached Thumbnails Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-img_20190522_171300-jpg   Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-cn6-retrofit-jpg   Masterwood Project 323 (1993) Retrofit under Tecnos GA PLC (near MW309)-config-io-masterwood-project-323-running-jpg
    Nov 2009
    Italy
    The sw in the pic in the DOS version of machine HMI.
    The firmware on 68000 card isn t compatible with the CPU 683, the SI2.5 could be compatible with both CPU.
    The axes card can depend on the firmware too
