SCM TECH Z25 Xilog Plus Software Issue
Results 1 to 3 of 3
Thread: SCM TECH Z25 Xilog Plus Software Issue
    Member vimuex3's Avatar
    Oct 2019
    Default SCM TECH Z25 Xilog Plus Software Issue
    We are a little carpenter's workshop and we have purchased an old machine. we have no idea how we can install software, it was work before, but from our worker, some system file was deleted, now machine is not working, i tried to reinstall, but still same
    Is Xilog the appropriate software to be able to program our machine in an easier way?
    Where could find the necessary software?
    How to install Xilog on my PC?
    Do exist a manual or tutorial for Xilog?
    Is it necessary to downgrade the OS to 32bits in order to use Xilog?
    Thank you in advance!
    Machine: SCM TECH Z25
    Year: 2006
    Serial Number: AL1/004546
    CidR's Avatar
    Mar 2020
    Default Re: SCM TECH Z25 Xilog Plus Software Issue
    Yes it is. unless you want to do a complete retrofit.
    You should try to contact SCM or an representative but i sure know that they are not the must helpful on a machine of this age....
    On a normal PC the program doesn't even need to be install just a copy of a working machine should do fine.
    I have it install on various office pcs.
    the help file provided on the software is the best help and one of few that exist.
    For programming on a office environment it isn't. i have on windows 10 x64.
    For the machine I am unsure but soon i will find out because i will try to install a different pc on my 2005 scm machine.
    Yours Truly,
    Cid Rodrigues
    Oct 2019
    thank you for the reply, really appreciate, yes we are trying with scm as well, if you know someone to help me with this through remotely, it will be grateful, and they is any way to contact you,
