Need Help! WoodWop 7 variable error
Results 1 to 2 of 2
Thread: WoodWop 7 variable error
    Member NachoHuizar's Avatar
    Nov 2020
    Default WoodWop 7 variable error
    Could someone give some advice on how to solve the variable error? I know it is something simple, but I really have no idea how to return it, the operator put the amount and then put the letter "i" to multiply it and convert it to inches, but It no longer does it and the old files of woodwop 7 stopped showing correctly, so I think that after changing the configuration, do you know how to reset the configurations or take steps back?Here I leave the sample images, if you respond, in advance thank you,
    Attached Files Attached Files
    Default Re: WoodWop 7 variable error
    I d'ont really understand what is your problem... Your dxf conversion seems failing, i think, did you put your workpiece on the correct named layer "S_18" or "ProcPart_18" where 18mm is the thickness of the piece? Are you sure your piece definition variable and woodwop variable are matching? Send a .mpr, i can take a look.
