Problem Laguna SmartShop 2 or Vcarve issue? - Tool Lengths changing! - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 36 of 36
Thread: Laguna SmartShop 2 or Vcarve issue? - Tool Lengths changing!
  1. #25
    Jan 2005
    Default Re: Laguna SmartShop 2 or Vcarve issue? - Tool Lengths changing!
    Quote Originally Posted by dangerfox View Post
    Yes, I was doing the manual set as well. I would compare the two and they were pretty much right on together.
    So it seems that everything is working correct with the control, so all you have to do now is to get Vcarve to work correct which by the program that you posted, you have the Z axes settings setup incorrect as they are way off for the Z axes moves, you where trying to do
    In your program if you where trying to cut through the part The Z axes move would be Z0.00
    The Z moves in your program are Z.933 and some are Z- so anything with a Z-this number will cut into the spoil board
    N180 G01 Z0.2793 F70.9 ( Cutting into the Part )
    N190 G00 Z0.9320 ( This is in most of the program and this would keep the Tool .200 above the part )
    N1080 G01 Z-0.0130 F70.9 ( This is cutting into the Spoil Board by .013" not much but is what you programed )
    Mactec54
  2. #26
    Sep 2017
    Hey so sorry ive been out since Sunday due to my 2 yr old son broke his femur on Sunday afternoon. We just got home from the hospital yesterday. Its been a wild last few days!
    This makes sense. I was reading the code and trying to follow the moves it would be making. Im not sure why any of the Z would be changing + or -. Also why the depth would ever go to the .9320.
    Im doing a screen capture recording on the exact process to export code in VCarve. I'll upload it in a few min.
    Thanks again for your continued support!
  3. #27
    Sep 2017
    Heres the link to the video I made of my VCarve process. Let me know if I'm doing anything wrong or if I need to change something.
    https://www.dropbox.com/s/l4uxhwwi3z...ocess.mov?dl=0
  4. #28
    Jun 2019
    ha noi
    Thank you. have a nice day!!!
  5. #29
    Sep 2017
    Did you happen to catch the video?
  6. #30
    Jan 2005
    Sorry missed it, I had a quick look and most seemed ok, do you do a preview of the cut before you make the G-code file, and then post the code here and I will check it
    Mactec54
  7. #31
    Sep 2017
    I checked two different files. The first file is what I've been working on, The second is a new file with a new shape, same thickness material and same cut depth. The tool is a stock .25 vCarve tool. Compare the two.
    Attached Files Attached Files
  8. #32
    Sep 2017
    I'm still thinking it's the machine. I've been reading the coding and it seems to be right. if the machine is changing the tool lengths that would cause the problem-- especially since the cut depths are very erratic and never the same from file to file. But my cut depths and material stays the exact same in every file.
  9. #33
    Jan 2005
    I did check your programs, they are no processed very well, and I could not run either until I changed some of the lines
    Dwell is normally G4 P5 not G04 5 I'm surprised it runs on your control like this although I have seen this before and can be just for your control
    These lines need the inside brackets removed
    (T5 = End Mill (0.25 inch))
    (T5 = Vortex - 1/4 Compression (.25))
    N90 (Tool: End Mill (0.25 inch))
    (T5 = Vortex - 1/4 Compression .25 ) This is normal
    N90 (Tool: End Mill 0.25 inch )
    Measure the amount the cutter is out of the holder, and then after you have used it, the tool could be moving out in the holder from not being torqued up enough
    Both programs are using the same cut depths but the Z clearance is very different
    Mactec54
  10. #34
    Sep 2017
    When you say “dwell” are you meaning the dwell at the bottoms of a hole function? If so, that function has never been checked in any of the drill tool paths I have.
    It’s funny you say they are not processed very well, cause this is the post processor Laguna provides. The longer I have this machine the more I want to get rid of it. The deeper I get into learning about these machines and how they function, the more I notice details Laguna failed to quality check. For a $50k+ price tag those issues shouldn’t be there!
    I’m gonna get on the phone with Laguna today and see if They have a solution as well. Maybe work it from the machine side for a min.
    Any other thoughts moving forward?
    I also went and bought a surface pro 6 to run VCarve from. I’ve been using Parallels on my MacBook Pro to run everything. I though that might be causing an issue. But that’s not been the case with the latest round of gcoding I’ve sent.
  11. #35
    Jan 2005
    No the Dwell is at each tool change it is normally used to wait for the spindle to get up to speed, so this is normal to have this for machines like this it is just the format they are using that is different, and this may be just to suit your control
    I'm sure the postprocessor can corrected there is a G70 in there also that is being used incorrectly and the brackets the dwell is normal they are just using a different format for it
    I don't think it is a computer problem but a windows computer is more suited to the programs you are using
    Everything looks to be ok and the programs do run, so I would be checking next that the Cutters are not pulling out of the tool holder going that deep this can happen
    Mactec54
  12. #36
    Mar 2017
    Is it possible that your home switch is moving from home cycle to home cycle?
