Help! Biesse Rover A smart Formula Codes.
Results 1 to 3 of 3
Thread: Help! Biesse Rover A smart Formula Codes.
    Member H2custom's Avatar
    Jul 2019
    Default Help! Biesse Rover A smart Formula Codes.
    I have a problem with inputting a formula into Bsolid that keeps crashing the software.
    I need to input TANGENT (TAN) also PI() but the software doesn't know it, Is there a way to do this, am I missing something. I can get my formula to work perfect in Excel (see EG)
    This is what I'm trying to achieve
    50*TAN(45*PI()/180) = 50
    I cant input PI() into Bsolid so I have to do it as 3.1415926536 as that is what it is PI=3.1415926536
    My formula in Bsolid is this but it gives me the wrong answer as its doesn't know what TAN is
    50*(45*3.1415926536/180) = 39.26990817
    Im also after any other helpful codes for SIN, COS, SQRT
    Also is there a way to reference tooling DIA into a program so when a cutter starts to get a little worn i can change the DIA of the tool in tooling and it will change it in all the programs that use that tool. EG: (LPZ- Tooling(10mm_CUTTER))/2
    Thanks all for any help
    Nov 2005
    Not sure on the upper end geometric functions in Solid, but all previous Biesse controls allowed their use so I think it may just be getting the correct syntax. Changing the diameter within the tooling tables provides for cutter compensation adjustment.
    Mark T.
    www.cnccustomservices.com
    Feb 2009
    Malaysia
    Default Re: Help! Biesse Rover A smart Formula Codes.
    PI is not available in bSolid, what you can do is to use the VARIABLES window and create the Variable PI=3.1415.. and set is as GLOBAL.
