Convert my pgm drawings to dxf without xilog
Results 1 to 5 of 5
Thread: Convert my pgm drawings to dxf without xilog
    Member Chris2104's Avatar
    Feb 2019
    Default Convert my pgm drawings to dxf without xilog
    Hi there can anyone help me convert my pgm xilog drawings to dxf dont have access to xilog plus no more is there and other sofware i can use
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Convert my pgm drawings to dxf without xilog
    Search ... Convert pgm to dxf.
    Feb 2019
    Hi ive tried all types of file conversion software and dont get no drawings from them i asked alphacam if there software was capable of it sent them a file and they sent a dxf drawing back but i nearly fell over when i asked how much alphacam was £4000????
    Mar 2003
    Shelby Township
    .pgm files are g-code, usually in a binary format. You'd usually use WinXiso to convert them to g-code text files. Then another converter to go from g-code to .dxf
    You'll never end up with the same drawing that you started with.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Feb 2019
    Thanks i have winxiso which xilog uses when i open the file theres all of the text x and z positions etc but just really struggling to actually get a drawing back from them i understand that if i do that the drawing will probably want scaled or so when alphacam opened them the drawing were exactly as they were
