Could be a bad contactor or relay.When I try to reset with the white button, it turns on for a few seconds and is off ...
Hello everyone,
I have a problem with a Masterwood Project 327 (1998 - Dos control MW309 - CN10).
I had not used this machine for several years.
When put back in function of the machine, plc no longer worked, so I made a Shift + PARM and sent the PLC.
Until all is ok, and now I have a code 0.0.0090 (emergency stop), I tested the electrical wiring and everything
is OK. The air pressure is ok, ...
How is it possible to control that the plc is well loaded and works well?
Thank you in advance for your answers
UCCNC 2017 Screenset
I'II Check
Is it possible to verify that the physical-PLC link does well in the "Machine Status" tab?
Sorry, I don't know enough to answer that. It's been over 10 years since I've used a 327.
Hi man, have you solved your problem? i have a project 315 and the error 0090 its my nightmare.. i dont know what to do..the machine its off since a week and i have a lot of work to do..any helps? thanks in advice
