The selection for chiller of laser cutting machine
The user of engraving machine should take the following important factors into consideration when choosing the circulation chiller:
1. Power of laser tube and application of laser machine.
Too high working temperature of laser tube will cause irreparable damage and reduce the output power of laser.The long working time is too high, and the life of the temperature laser tube will be greatly shortened. For example, the larger cooling machine should be considered when the power and luminescence rate of the laser tube are higher.
2. Working environment temperature of laser machine.
The general cooling machine has low temperature protection function, when the water temperature is less than 10 ? to stop a cooling fan.Therefore, it is important to consider the case of high temperature, if the working environment temperature is higher, it should consider the larger cooler.
3. Requirements on cooling water temperature for laser processing technology.
The temperature fluctuation of larger coolers is less when cooling the same heating system, which is beneficial to the stability of laser output.
