How should we maintain the idle and the frequent cnc router? Today we will talk about the use of the cnc router should be how to maintain!
CNC Router in idle when simple rust, because wet workshop environment, especially summer, when some parts of CNC Router is eary to simple rust, such as: bed, spindle, guide rail and other metal parts. So, suppose the rusty CNC Router spindle, what will happen? First of all, it must have an impact on the engraving function of the engraving machine.
What measures and precautions should we use to prevent the rusting of the cnc router?
1. The outer surface of other steel parts, such as ball screw, hardened steel raceway of guide, and the outer surface of steel fasteners, shall be dipped in butter with cloth or cotton every few days. Other parts, should often investigate whether there is little rust, if applied cloth oil wipe, and as the future rust prevention.
2. For another appearance made of aluminum, it should be dipped in butter every few days, or sprayed with varnish.And often investigate whether there are erosion points.
3. Pour emulsified oil into the cooling water tank to prevent rust. Do not use water.
Angela: +86-13181731899 sales01@yxhcnc.com CNC Router, CNC Router Machine, Wood CNC Router, Wood Working CNC Router, ATC CNC Router Factory
- - - Updated - - -
YXH 4 axis ATC cnc router machine debugging, do you like it?
