New Machine Build cnc build what ya think
Results 1 to 4 of 4
Thread: cnc build what ya think
    Mar 2018
    Default cnc build what ya think
    cnc build what ya think-split-frame-base7-inch-gantry-v4-v13030 lower frame 60x63
    3030 risers 7 inchs
    1530 caps
    and 1530 cross members
    60 x 25mm guildeway
    gantry 3060
    and 2010 ball screw on all 3 axis
    servo drives
    do think this will work
    looking for 400 rapids speed of cut depends on materals of course
    Attached Thumbnails Attached Thumbnails cnc build what ya think-split-frame-base7-inch-gantry-v4-v1
    Member awerby's Avatar
    Apr 2004
    Default Re: cnc build what ya think
    It looks okay so far, but you've still got a lot of work to do on the design. How do the motors mount? Where do the ball screws go? What does the Z axis assembly look like? What are you using for a spindle? Does it sit on the ground, or on a table of some sort?
    Mar 2018
    Quote Originally Posted by awerby View Post
    4.5 Kw Spindle er 32
    working on the z axis under design,
    x axis will be on back with a 1in plate attached to the z to move it from side to side ( ill send drawings)
    y axis will have 2 ballscrew / one on each side (Y A Slaved)
    Mar 2018
    Im not sure of a table , need something rigid not sure what yet, steel welded, 8020 , or other
    have some time , this is a build over time project. not doing it all at once
