How version you need?
Via iPhone of the Tapatalk
Where can I find XILOG maestro to install, can someone tell for 32 or 64 bits system
hi there , u seem to know a lot about scm . can u please tell me how to make the machine move back to home position and drop the tool . or how to remove a tool manually . the v45 degree bit sems to be not in place and whenever i run the machine it doesnt recognize it , and freezes . even when i command it to use a different bit it still doesnt . so am assuming that removing the bit manually or making the cnc go back to home position and drop the tool will fix it . plz i need ur help . thks in a advance
Hello dear Colleague,
I understood that your machine stopped while performing a tool change.
If the spindle is close to the tool magazine you need away from it manually in power or not.
Once you are at a considerable distance you must put the machine in power and perform calibration (F5).
When run calibration (F5) in MDI (F6), has the (F12) or Shift + F12.
You can command the opening or closing motor.
For this select the aperture icon + Enter + Start (Mobile Control).
Hello, Is Ok?
kris1974
you already have the software xilog maestro? If yes then send me with. Thank you.
Hi Luxury, I send the new version of the Xilog Maestro for you.
https://drive.google.com/file/d/0B67...ZBMmxnSWs/view
Hi. No, this is not possibile.
You must buy Maestro from SCM
Have you moved the software package for download?
Google Drive reports file no longer exists!
