Shenyang Hermos CNC Machine Tool, is mainly producing three series of products. They are CNC internal grinding machine, CNC surface grinding machine and cnc hard lathe machine. Of course, Hermos never stop it’s research in new products.
As for different category, the industries vary. Here let’s introduce you some industries can be reached with Hermos CNC Surface Grinding Machine.
To be spedific, some industies like auto industry, pumping industry, and mechanic industry. Many parts of those industries can be produced with internal grinding machine.
Let’s have some cases for your information.
1. Micro compressor, which is an important part for refrigeration system. Machining parts like swash plate, slide block, stator, rotator, piston, cylinder, roller cover and bearings can be produced through Hermos CNC surface grinding machine.
2. Pumps, like peddle pump, piston pump, hydraulic pump and oil pump, many important parts for those above pumps can be produced through this grinder like press board, retainer plate, rotator, pump cover, stator, oil distribution casing, flat washer, slide plate, spacer, and located rings.
3. In auto industry, most auto spare parts auto friction plate, auto end plate, auto copper pad, auto washer, auto valve, auto plate, brake plate and auto pulley.
Those above are just some indsutries illustrated. There are many more areas can be reached with Hermos CNC automatic surface grinders machine. We will keep searching as a manufacturer. We are also looking forward to your sharing knowledge and experience.
