Make sure air is connected and correct pressure
Turn on main switch
Press white button on controller to reset the emergency circuit. If it does not reset check the trip wire on the front of the machine has not been activated. If it has push the yellow button on the end of the trip wire to reset, then try the white button again.
Go to manual movements on controller
press sizing
then press start
Machine should then size
If you have any more problems pm me and I will post a video for you.
