you have three sensors in main head you must took a metal sheet that cover them, and you should clean the second or middle, probably is a lot of metal dirt on it but just be careful with it its positioned with micrometers and you should put it back how it was been, and the worst is that is sensor damaged and you will need buy new one
if you dont find it i can send you picture where to look
