Cimco Edit 6 tool list
Results 1 to 3 of 3
Thread: Cimco Edit 6 tool list
    Registered Schrudo's Avatar
    Dec 2002
    Wegberg
    Hello
    I just worked my way into CIMCO edit6. There's the feature for the tool list and I wondered if one can also customize it to its own needs?
    If so how does that work?
    What can you adjust it?
    Thank you!
    Registered bullet01's Avatar
    May 2009
    Buchstehude
    Hello
    Go to Settings -> Other,
    Push the button on the tool list
    and there is the tool list template.
    Then you can go back to the editor
    then the txt. opens,
    which you then may adjust as you desired
    and then of course save it afterwards.
    Dec 2002
    Wegberg
    Yes, I have found and adapted the file.
    In my programs the first three lines are always the workpiece name, drawing number and what type of clamping it is, can I also automatically let it being entered into the tool list?
    I wrote the first 3 lines always with an outline.
    Thank you!!
