Cimco V6
Results 1 to 11 of 11
Thread: Cimco V6
    Registered Cncplaner's Avatar
    Dec 2011
    Berlin
    Hello
    I have the following problem:
    If I open two files in Cimco and I want to change something in one of the files, then it doesn’t let me. But why?
    I would like to keep both files open.
    And I also don’t want that it changes everything from the right side to the left side or vice versa- I only want to change certain things that I CHOOSE to change.
    Thank you in advance
    Kasi909's Avatar
    Apr 2005
    Bad Salzuflen
    Hi
    That is no problem.
    Could it be that you want to compare 2 files and then change one of them?
    Regards
    Karsten
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->&quot;Menschen mit einer neuen Idee gelten so lange als Spinner, bis sich die Sache durchgesetzt hat.&quot;<!--sizec--></span><!--/sizec--> <!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Mark Twain<!--sizec--></span><!--/sizec--><br /><br /><br />CAD/CAM<br /><br />Programmierung - Prozessoptimierung - Automatisierung <br /><br />www.vcc-production.eu
    Dec 2011
    Berlin
    Yes, exactly. I compare two and then change one.
    Kasi909's Avatar
    Apr 2005
    Bad Salzuflen
    And what exactly doesn’t work?
    When comparing files you can either adjust things row by row or everything at once.
    If you don’t want to have it like that, then you can also adjust things manually
    Regards
    Karsten
    Dec 2011
    Berlin
    No, that doesn’t work.
    Either in the left or in the right column, I cannot change a coordinate, rotation speed or something else.
    Only a “piep” noise comes up.
    When I press delete or want to insert something then that noise is there and everything stays unchanged.
    What am I doing wrong?
    Dec 2011
    Berlin
    I have just found it in the manual. Really unfortunate:
    The editing of a file during the file comparison is not possible on purpose!
  7. #7
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Do your settings fit under file comparison?
    It’s possible to switch from one window to another with the tabulator.
    And it’s then possible to edit each block.
    Also both windows stay open that way
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
  8. #8
    Registered bullet01's Avatar
    May 2009
    Buchstehude
    Hello
    Have a look if your programs are write-protected.
    Because if they are you cannot change them.
  9. #9
    Dec 2011
    Berlin
    Hello
    The settings are set to the original values.
    And the files are not write-protected either.
    The takeover from left to right and vice versa works but edit individual blocks isn’t possible.
  10. #10
    May 2009
    Buchstehude
    Please describe your course of action a bit more detailed.
    Step by step so that we can understand it better.
    Preferably with screenshots
  11. #11
    Dec 2011
    Berlin
    So open Cimco
    At the top in the rider press “file comparison”
    Then compare file with file
    Then select the two files
    That’s it!
Cimco V6
Cimco V6
Cimco V6
