Hello WalterHello
I created a font with Cimco edit V5.5. Everything is OK but the program doesn’t have any feed in CNC Editor, neither HH Dialog, nor DIN.
Do I have to program it manually? Is it possible to assign feed to colored traverse paths? It’s strange but there’s feed for rapid motion FMAX. So I need feed motions for covering in Z and for traverse paths in XY. There’s a macro monitoring but I don’t really understand the sense of it.
J. Walter
Cimco Edit with CNC Clac outputs only the contour first. Then you can enter program heading, tool change and feed motions in NC editor via NC assistant. It’s for a milling cutter and the material that’s going to be machined.
Greetings
t.sprehe
