Cimco simulation
Results 1 to 10 of 10
Thread: Cimco simulation
    n2l's Avatar
    Nov 2006
    Hello
    I installed a demo version of cimco editor 5.6 to exercise as long as I stay home.
    But when I try to add a program to blackplot, the following error occurs:
    Machine not defined
    Here is a screenshot of the settings:
    n2l's Avatar
    Nov 2006
    And a program
    It’s just a test!
    Registered bullet01's Avatar
    May 2009
    Buchstehude
    Could you show the error message, too?
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    And a program
    It’s just a test!
    Hello n2l
    It’s a Fanuc program.
    Try this one.
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello n2l
    Try this one.
    Regards, InTex
    n2l's Avatar
    Nov 2006
    Still the same error.
  7. #7
    Administrator CNCFanatiker's Avatar
    Dec 2001
    EE-Kreis / Germany
    Hello n2l
    Did you define the machine in DNC settings?
    If you didn’t, then you should do it.
    One can see a dropdown menu at you screenshot – there’s nothing chosen there – check if you may choose a machine there and try again.
    If it doesn’t help, look in the settings under spec. file types -> CNC-machine/Backplot and check whether everything is correct there.
    Gruß / Regards
    CNCFanatiker
    AdminCrew
    Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.
    If we always this act what we are able to do, then we always remain what we are.
  8. #8
    Kasi909's Avatar
    Apr 2005
    Bad Salzuflen
    Hello n2l
    Hello
    The icon menu belongs to DNC Max and has no bearing on simulation. Programs are simulated with standard installation without program adjustment. Check your settings under Backplot.
    Greetings
    Karsten
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo-->&quot;Menschen mit einer neuen Idee gelten so lange als Spinner, bis sich die Sache durchgesetzt hat.&quot;<!--sizec--></span><!--/sizec--> <!--sizeo:1--><span style="font-size:8pt;line-height:100%"><!--/sizeo-->Mark Twain<!--sizec--></span><!--/sizec--><br /><br /><br />CAD/CAM<br /><br />Programmierung - Prozessoptimierung - Automatisierung <br /><br />www.vcc-production.eu
  9. #9
    n2l's Avatar
    Nov 2006
    So guys
    The problem is solved. The 5.6 version was the reason. Everything worked at first go with the version 5.5.
    But thanks a lot for your help!
  10. #10
    Kasi909's Avatar
    Apr 2005
    Bad Salzuflen
    So guys
    It also works with the 5.6
    Greetings
    Karsten
Cimco simulation
Cimco simulation
