No. A servo is just a motor, a somewhat specialized motor, but none the less just a motor. It may have been built to a standard size like NEMA23.Not quite clear on this yet but are you saying any servo needs a NEMA motor to get going?
The motor would still work if it were a few mm bigger or a few mm smaller but it would not sell nearly as well because all the machines out there have been made
for a standard sized motor. If the servo blows up in your printing press for instance you want to be able to ring up and get another, you don't even really care if its from
the same manufacturer, just as long as it fits in the hole and works.
I suspect that DMM have some standard NEMA sizes and some metric sizes. If you are trying to repair an existing machine then you want to choose the rightAnd why DMM is asking about the NEMA dimensions? If the servo and NEMA are matched why do I care for the rest?
one. If you are building from scratch, then it does not matter.
Craig
