Okay, how’s this. Green representing working area with stubby 2cm tool and red representing spindle collision boundaries with the table at max plunge depth, and stock in yellow. I don’t have much experience but I think mastercam and the like allow you to input a simplified model of your machine and work holding, and will route tool paths to avoid collisions? Obviously I can’t achieve the full work volume without risking possible collisions with rotary, table, etc.
I’m glad to see some support for the horizontal layout, it seems to be less popular compared to VMC type builds but I’m convinced it does indeed make sense if your work holding allows it. ATC would be great but is not in the budget for now, if I find more funds later I would replace the spindle with one of those BT30 all in ones. Carousel would likely be located above spindle mounted to top of column, if there is vertical clearance above the machine.
Now onto electronics, playing around with the calculator at
https://www.orientalmotor.com/motor-...ew-sizing.html I get <2Nm torque required even with the 10mm pitch screws, not sure how valid this is because I don’t know about accelerations or typical machining forces.
For steppers I am tentatively looking at
https://www.aliexpress.com/item/4001034467781.html
2.2Nm with 1.3mH inductance. Kind of expensive for a stepper but it claims much less inductance than comparable Nema 23s, most of them seem to have >3mH inductance for that torque range. Makes you wonder if those claims are any good. I would appreciate everyone’s thoughts on motor sizing, I really have no idea about what’s adequate here. Also, if anyone has leads on cheap steppers and drives available in Canada that would be great. Thanks all for your feedback so far.
