Originally Posted by
j2345
Thanks for the info, it seems like various ways of clamping the top surface to the table are pretty simple.
Yes, current plan is to cast an angle out of concrete, face and bore after the machine is running 3 axis, then bond in an aluminum sleeve to hold a harmonic reducer. Currently lurking ebay searching for a good and cheap one, I really want a thru-spindle bore on the reducer so I can tighten an expanding arbor from the rear of the head stock instead of having to go through the part. I have not done any CAD on this yet but it should be pretty simple once I find a suitable reducer. Hopefully a cheap NEMA17 I have laying around will be fine for this at 50:1 reduction.
