- Critique my CNC Column Mini Mill
Re: Critique my CNC Column Mini Mill
@joeavaerage. Would you mind sharing some photos of your build? I was curious Or do you have a build log?
I see your ballscrews are currently clipping into the model. One thing I regret not doing on my build is using larger than necessary profile rails that match the height of the ballscrew. It's much easier than shimming, and probably not too much more expensive.
That looks massive. Thank you.
- You may not post replies
- You may not edit your posts
Forum Rules
