CNC Milling Machine
Results 1 to 2 of 2
Thread: CNC Milling Machine
    Member Brazzo's Avatar
    Aug 2021
    Default CNC Milling Machine
    Hi guys i have been building a DIY metal milling machine.
    I bought all i needed i have the Masso G3 drive
    Nema 34 12nm closed loop stepper motors with the corresponding drivers
    im using one power supply per stepper motors
    i have 4 axis
    6.5KW spindle with VFD
    have finished the machine and finished building the power box now i have no idea on how to connect the whole system.
    Member awerby's Avatar
    Apr 2004
    Default Re: CNC Milling Machine
    Usually you only use one power supply for the whole machine, although sometimes you can use a small separate one for logic-level signals if your main PS doesn't have a low-voltage tap. Why did you decide to use one for each motor? Here's what Masso recommends for the G3: https://docs.masso.com.au/getting-st...ering-masso-g3 It all seems a little underpowered for NEMA 34 motors, though. It's rare to find a 34 motor with low enough inductance to work well on 24 volts or less.
CNC Milling Machine
CNC Milling Machine
