use Enable terminals with a toggle switch as a stand by mode
Results 1 to 2 of 2
Thread: use Enable terminals with a toggle switch as a stand by mode
    Member danbob5's Avatar
    Jun 2020
    Default use Enable terminals with a toggle switch as a stand by mode
    I am using a nema 34 stepper to drive the lead screw on my HF 9 x 20 lathe. It is used strictly as a variable speed motor. i need to know how to wire the enable terminals with a toggle switch to use them to put the driver in basically a stand by mode. Also i will use the standard gears to cut threads When i am using the gears will the stepper generate electricity and damage the driver? Dan
    Attached Thumbnails Attached Thumbnails use Enable terminals with a toggle switch as a stand by mode-sam_1872-jpg
    Dec 2013
    Default Re: use Enable terminals with a toggle switch as a stand by mode
    Quote Originally Posted by danbob5 View Post
    That should work OK.
    Yes, the stepper will become a generator and most likely will damage your stepper drive. I would put a plug on the motor cable so it is easy to disconnect when using the geared system. Make sure the power supply to the stepper drive is off when connecting/disconnecting the motor cable.
    Jim Dawson
    Sandy, Oregon, USA
