Soliciting advice for unusual build - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Soliciting advice for unusual build
  1. #21
    Aug 2014
    Default Re: Soliciting advice for unusual build
    Quote Originally Posted by peteeng View Post
    Hi Zorbit - How do the blocks get reset for the next scene? This would be like those pin cushion things you place on an object to capture its shape...Peter
    You could have a roller pass over the top surface, or just a flat board to press them down. Maybe seal the bottom and use a blower as a vacuum pump if you wanted to over-complicate things.
  2. #22
    Aug 2014
    That's a good description.
    I think the key is that you don't need control over every block in a random fashion, the game is likely to demand walls and rooms which means lots of straight lines.
  3. #23
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hey Aad - heres something but not good fo0r walls. Peter
    https://adapa.dk/
  4. #24
    Jul 2018
    dum dum
