Small Concrete CNC Mill - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
Thread: Small Concrete CNC Mill
  1. #41
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Small Concrete CNC Mill
    Hi Juan - Nice but it will need a cross brace or two. These machines do have some inertia and will move a table around.... Until you fill up the bottom with lots of heavy stuff... Peter
  2. #42
    Nov 2017
    Quote Originally Posted by peteeng View Post
    Sure, I have some pieces left just for that. But I'll wait to see where they're needed most. The bottom "shelve" will get surely filled with stuff...
    Juan
  3. #43
    Nov 2017
    I've glued some of the pieces together, but I've run out of wood glue and so did the hardware store apparently. I've also tested the power supply and the stepper motors and drivers which have recently arrived and everything works as expected.
    Last thing I've done is aplying epoxy to the surfaces the rails will mount to. Attached is a photo of the saddle, I'll do the others next. The wood absorbs the epoxy nicely, I think it will be fine. There will be some epoxy left to coat other parts of the frame as well.
    On the Z axis brake, I initially thought of using a resistor across the stepper windings, however that would only make the spindle arm fall slower, it won't stop it. Instead I'll use a small solenoid whose plunger goes into a disc with some detents attached to the ballscrew. When not activated, the plunger will fall into a detent, and when energized it will let it rotate freely. The solenoid will be activated by the stepper enable signal. It won't maintain the exact position, yet that can´t be trusted anyways if motors have been disabled. Way cheaper than a commercial stepper brake.
    Due to academic reasons (back to work!) any further development will slow down to a crawl until summer. Perfect times for letting glue/paint/resin dry .
    Juan
    Small Concrete CNC Mill-epoxy_reinforcement-jpg
    Attached Thumbnails Attached Thumbnails Small Concrete CNC Mill-epoxy_reinforcement-jpg
