Dual MPG question
Results 1 to 3 of 3
Thread: Dual MPG question
    steve-t's Avatar
    Oct 2020
    Default Dual MPG question
    Hi all,
    I converted an old mill successfully which is driven by a DDCSV1.1 controller. I am now looking at setting up on the same machine an MPG for X and another MPG for Y with feedrate dials. How could I go about doing this? I attempted 2 usb mpg's simultaneously which didnt work. I also attempted wiring up the mpg's directly into the motor drivers but turning the dials hardly moves the motors. I dont want to change settings on the driver as this will then conflict with the DDCSV1.1.
    May 2016
    Default Re: Dual MPG question
    You can't really get there from here without some additional hardware.
    Page 13 of the manual indicates there is a single A/B encoder input, and then you select an axis and step value from multi-position selector switches. There are no programmable inputs on that controller where you could 'add' another MPG.
    If you are trying to add an MPG on each physical table handle it might be possible to run the two MPG A/B inputs through a 4PDT relay. But you'd still have to choose the selector switch to tell the controller which axis to move. i.e. flip relay and also change selector switch.
    Unless you're willing to rig up the MPG's to an Arduino and program it to look for state changes on both MPG's. Then Arduino sees state change on MPG-X and sends A/B encoder signals while also grounding the X-IN terminal. And similar for MPG-Y.
    Even then you can't run both axis at once - even if the controller is so dumb it'll drive both axis at once (if the X-IN and Y-IN are both grounded) it'll just move them at the same feedrate. There's no way to get simultaneous motion at different rates.
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by steve-t View Post
    Hi all,
    Only one MPG with long cable could be the solution.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
Dual MPG question
Dual MPG question
