Hi all - While my computer was thinking about a mesh I did a quick calc on the 12mm vs 16mm ballscrew. I intended using 5mm pitch, this gives 345kgf thrust, a 10mm pitch will give half that at 173kgf which is probably plenty. A 1000mm long 12mm screw whirls at 1867rpm so steppers won't get to that, servos can. A 1000mm 12mm screw buckles at 403kgf and usually a SF=2 is used for bump loads etc. so a 203kgf allowed for buckling means the 10P 12mm screw is OK as its 173kgf but the 5mm pitch is not OK.
Looking at 16mm buckling, it buckles at 563kgf so will do all cases.... 16mm stay with, I think said Yoda.... Peter
My overall screw lengths at the mo are X985mm Y715mm Z660mm. The distance to the nut is maybe 200mm shorter so maybe do to the nut to be a little more accurate.
checking nut distances X746 Y321 Z445 so using 750mm instead of 1000mm gives an allowable buckling load of 361kgf which is OK with P5 ballscrew.. Maybe worth a look... just finished meshing some 1M elements too big have to remesh...
