Hi Pippin - Re laminates - I built a 50x500mm cantilever. One is solid aluminium 2.5mm thick the other is 2mm al/0.5mm epoxy and 2mm al... I then did a modal analysis and they both free vibrate at similar frequencies, 10.32 vs 10.25 64.14 vs 64.63 etc. I then did a dynamic analysis using 3% damping ratio with a 0.5sec load spike. The laminated beam stopped vibrating in 4 cycles the solid beam in 7 cycles. Can't show this easily I had to run the output in slow mo and count cycles. This is based purely on the elastic ratios of the materials as damping in this case is same for all materials. (I have sent a note to the software people to change the damping to a material property vs a structures property) . Hysterisis and interfaces would improve this I'd expect. So laminates work. Peter
