CNC METAL SPINNING MACHINE
Results 1 to 2 of 2
Thread: CNC METAL SPINNING MACHINE
    Member ahmadelwaly's Avatar
    Aug 2020
    Default CNC METAL SPINNING MACHINE
    I need to make a desktop spinning machine like this :
    i want to ask about what's the controller i can use it and framework and what about the software generated the G-code.
    Member awerby's Avatar
    Apr 2004
    Default Re: CNC METAL SPINNING MACHINE
    Usually that process is done on a lathe. If you want to make a CNC version, start with a CNC metal lathe and use CNC lathe CAM software to design the tool paths that guide your pusher.
