- Jitter on X axis while moving manual or gcode controlled
My X axis is no longer moving smoothly. This is on a chain drive system. The control device allows for Continuous mode which normally just allows me to smoothly send the X axis in either direction. It looks like it's just doing continuous single steps rather than smoothly running as before. I can move the X axis when powered down but not while engaged so I know the power is getting to the motor. Any ideas of what to look at?
- You may not post replies
- You may not edit your posts
Forum Rules
