If your machine is a BP clone, then I don't see a problem with 4140, just keep it oiled. The original quill stop was made of steel of some kind, and when I added the Z feed to my CNC I built the new block out of 4150. They probably thought bronze would be a better bearing on the edges of the keyway, but steel on cast iron is a pretty good bearing.
