Linz french lathe retrofit with Centroid Acorn
Results 1 to 1 of 1
Thread: Linz french lathe retrofit with Centroid Acorn
    Jun 2012
    France
    Default Linz french lathe retrofit with Centroid Acorn
    Hey
    I am in the process of fitting a previously manual lathe with a Centroid Acorn board and Clearpath motors.
    This kind of lathe manufactured by Linz, and a smaller model by Haulin, are made of a welded sheetmetal frame, while the slide rides on ground and nitrided 65mm rods. This setup is known for accuracy, stiffness and very small footprint, which I need above all.
    Here are a couple of videos - in french though. If this thread shows interest I'll make some english videos.
    Thanks,
