groove table plate
Results 1 to 2 of 2
Thread: groove table plate
    Registered Nico95's Avatar
    Nov 2011
    Ellerstadt
    Hi people,
    I've recently bought a fairly simple CNC milling machine
    http://gocnc.de/product_info.php?cPa...db2a10309a61a7
    following: The router is supplied with a wooden board as a milling plate. Because it bents easily and I can only attach my work pieces with double sided tape, I now want to exchange it for a groove table top. The problem now is that I have not yet found a suitable plate with the right dimensions (52x37mm), height 15mm max.
    Maybe someone has contacts with people that manufacture such plates to measure or know a good website.
    Regards Nico
    Registered Ma_Hermann's Avatar
    Mar 2011
    Saalfeld
    Hello
    Look at your measurements again. (52x37mm) It’s a matchbox.
    Have a look on the internet with Google yourself, you can write "t-groove plate" or something in the search.
    Greetings Matthias
groove table plate
groove table plate
groove table plate
