Syil C6 with Mach3
Results 1 to 4 of 4
Thread: Syil C6 with Mach3
    Sonnee's Avatar
    Mar 2010
    Öhringen
    Hello
    I bought a CNC turning machine Syil C6 with CNC Super Box and the Mach3 controller software.
    Does anybody happen to know the correct PIN settings for the output signal for X and Z axes and also PIN settings for the spindle speed indication?
    Regards, Sonnee
    MFG <br />Sonnee
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello
    Regards, Sonnee
    Hello
    Motor output
    X-axis ---- Step Pin# =3 Dir Pin# =2
    Z-axis ---- Step Pin# =5 Dir Pin# =4
    Output signals
    Output1 ---- Port# =1 Pin number =14
    Output2 ---- Port# =1 Pin number =17
    Spindle relay settings
    Clockwise rotation (M3) – output# =1
    Counter clockwise rotation (M4) – output# =2
    These are my settings shown in a test of 2-axial controlling card.
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Sonnee's Avatar
    Mar 2010
    Öhringen
    Hello
    Motor output
    Output signals
    Regards, InTex
    Hello
    Unfortunately, the machine still doesn’t work. None of the axes wants to move.
    What can be the reason?
    Regards, Sonnee
    MFG <br />Sonnee
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    It can have a lot of reasons. Motor current settings. Does your parallel cable suit? I don’t know where you bought the machine.
    Do your stepper have a noticeable holding torque? Does the logic power work?
    You didn’t give us really enough information saying that you need PIN settings. It would be nice to know more details.
Syil C6 with Mach3
Syil C6 with Mach3
