- Citizen L4L32 QX086 power supply
Hello
Having trouble with the power on button located on the controller. Machine turns on fine, but wben trying to turn the controller on nothing happens. So I did notice the power supply QX086 unit was not powered on so ordered a new one and replaced but still having the same issue. I have good power going into the unit and coming out of one of the output. The only output I do not have any voltage is the wire going to the blacklight/button circuit board.
- You may not post replies
- You may not edit your posts
Forum Rules
