There were multiple versions of the B12. You should state which generation you have and inch or metric. Which control?
Lost the parameters and the ladder program for my Cincom b12, and don't have a backup!! Please help if you have a backup of its memory. Should be two or three files... Would be much appreciated! Machine down currently!
Al
- Need Help!- lost pmc parameters for SMG model V32 mill and backup
- Need Help!- CNC CINCOM B12-Calibration
- Need Help!- CINCOM B12
- Need Help!- CITIZEN B12 CINCOM ERROR
Thank you for responding. Its a 1995 machine, with Fanuc 18B series.
As for metric or inch, I think it can change unit in its setting.
Any help would be appreciated, even if the PMC code is not for this particular version, it could help us by giving us ideas for writing the ladder code for it.
best
Al
You didn't loose your ladder. You lost the option bit that states which PMC you have so It won't get displayed till you recover the option parameters. Call Fanuc and see if they have record of that machine. You are going to need the control serial number and if Fanuc has ever worked on that machine and by chance made a backup of that control they may have the backup.
