- CNC Monitoring for Cycle times
We recently installed a new citizen cincom L20 with a Mitsubishi control. We are trying to implement Machine Monitoring with an SAP based MES system. We have purchased and installed Mitsubishi IMA adapter to obtain Machine tag information. We are having a problem seeing tags which will can reliably be used to identify the cycle start and cycle complete. Has anyone else attempted machine integration with the Mitsubishi IMA adapter and which tags do you use to identify cycle start and cycle complete?
- You may not post replies
- You may not edit your posts
Forum Rules
