Touching off end face tool in B-axis
Results 1 to 2 of 2
Thread: Touching off end face tool in B-axis
    Member MNhockeyguy's Avatar
    Apr 2020
    Default Touching off end face tool in B-axis
    We got a brand new L32 type xll so it’s got all the bells and whistles including a full b-axis. I’ve never used one before. So I touch off the tool on the face of my bar after performing a cutoff with a LH tool like it says but now when that tool is called up while I’m running it’s not even close. I added a g50 shift of .591(15mm) and still not close. My only thought is it’s something to do with using the G910 b0 command or I’m missing something obvious.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Touching off end face tool in B-axis
    hy, i have experience with citizens, but not with b axis .... i googled it : yes, looks nice
    i have good manuals for citizen, but not with b axis ... look inside yours, maybe there is something
    i would measure it like a normal tool, and try to use it without rotating ( maybe in mdi, or by creating a small program ), at least to have a clue if offseting works ok... after that, i would activate the b axis, and check again
    it may be possible that B axis has it's own wcs, in respect to the pivot point ... ask for a cutting code from your dealer / kindly
    ps : is not a must to use a lh tool for cutting, you may setup up the cut-off / facing however you like ... it may be possible that during cut-off you have somehow a shifted coordinate; do you have experience with normal citizen, without b axis ?
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Apr 2020
    Yes I have about 4 years experience running citizens just have never used a B axis before. I was able to figure it out today finally. After touching the tool off as it says in the book when you call up g910 B0 there must be a D1 right after the B0. Not entirely sure why it has something to do with the following line below it but once I did that it’s now cutting finally without me having to cheat by adding a ridiculous offset.
    QUOTE=deadlykitten;2369942]hy, i have experience with citizens, but not with b axis .... i googled it : yes, looks nice
    ps : is not a must to use a lh tool for cutting, you may setup up the cut-off / facing however you like ... it may be possible that during cut-off you have somehow a shifted coordinate; do you have experience with normal citizen, without b axis ?[/QUOTE]
