Drill tool holding
Results 1 to 3 of 3
Thread: Drill tool holding
    Sep 2006
    u.s.
    Default Drill tool holding
    Recently purchased a '95 Citizen E 25J . I had never operated a swiss lathe before so bear that in mind. Have it running fine and dandy.
    However i am curious what most people are using to chuck drills into the tool holders with on these machines.
    I had to make some custom sized sleeves to mount the drills into the bore of the tool holders. Its working fine but this is not a good way to operate long term. Especially when i need to make quick setups in the future. On all my other CNC lathes i just buy ER32 collet holders with a straight shank and mount them into the tool holder bores. However there is not enough room on this Swiss machine to add an ER collet chuck and still have a drill longer than maybe 1/2" mounted in it.
    Feb 2011
    Default Re: Drill tool holding
    most of the holders that i use are er16 collet sleeves mostly from genswiss
    Sep 2006
    u.s.
    I do have some ER16 chucks with straight shank. Still lose almost 1" of Z from the collet nut sticking out but considering the small parts that probably will be ok for most jobs.
Drill tool holding
Drill tool holding
