- Citizen M32 2002 C axis indexing not work
I have a citizen m32 2002 cnc machine problem on C axis when I start the program blocked on M18 C0 even on MDI it does not work there is no alarm nothing
Re: Citizen M32 2002 C axis indexing not work
Has the option for main spindle C axis been switched on check in the machine structure page
thank you for the answer tomorrow I will check the machine structure page and I will signal you
hi brother i hope you are fine thanks so much for your support i found the solution the problem on the cat plg sensor of the main spindle
- You may not post replies
- You may not edit your posts
Forum Rules
