- Citizen 1999 L432 Meldas 500L error messages?
Re: Citizen 1999 L432 Meldas 500L error messages?
I have that exact machine setup. that barfeeder alarm will show up every time you power up until you get the barfeeder turned on. once you power the bar feeder and hit switch S73, then the manual or automatic button,then you will clear the barfeed alarm
I have had that 2Z70 ABS. ERROR 0004 before. give Mitsubishi a call, but I think you need a new z axis servo drive. I have one for that machine if you want to try that.If that alarm can be cleared by doing a zero return, Its easy. go to parameters,type in 17-enter then 18 and enter then cycle start. that will home x1. then you hit 19,cycle start,20-cycle start,21-cycle start, 22-cycle start.
Reason: more info
Where are you I think I decommissioned that machine
Rochester, New York - USA
Sorry guys, I did not get any notification I had responses to this thread. Thanks for taking the time. The problem with the machine was narrowed down to a blown servo motor on the X2 and operator error (!) . I'm located in Essex
2z err abs if origin of axis z2 it is not a problem the problem on the locked emergency stop it is necessary to check the safety relay on the machine or on the bar loader
- You may not post replies
- You may not edit your posts
Forum Rules
