Z70 is a zero return alarm
Zero return all axis the only one that could be a problem is T1 there is a procedure for this if you need it
Hello all.
We have a M20 Citizen CNC machine, with this alarm,
Z70 Abs Data Error, 0001 Z1
Z70 Abs. Data Error, 0001 Z2T1
Z70 Abs Data Error 0001 Z3.
This Machine was down for a power supply 220 vac to 24 vdc. we replaced the power supply but this alarm is showing.
Can you help us?.
You have to make the origin of the machine but first you have to do it before t1 turret If you want to get the procedure ch.assraoui@gmail.com
Hi . good day . I have a Cincom M20 lathe that has Z70 data error alarm 0004 A, thank you if anyone can help
Z1 axis needs a zero return
Greeting
I saw your post in CNC zone website (https://www.cnczone.com/forums/citizen-machines/270906-cnc.html )
And i have the same problem here Could you please teaching & tell me what is the solution, I have been exhausted of this problem and thank you very much
Best wishes
email: badrezzine1991@gmail.com
Whatsup: +21628685557
