- Need Help!- Fa10 mit. Wire EDM. Alarm S02 INIT PARAMETAR ERROR
Can anyone give a consult about the alarm the manual say to check parameters from the drives but how do i even check those parameters.
on the drive there is f1 e7 f2 e7 blinking.
Also how do i know if the nc card is working like it should.
pls help
Fa10 Wire EDM Alarm S02 INIT PARA ERROR
Can anyone give any suggestion about my problem.
The monitor shows s02 init para error. does this mean that the nc card is not giving parameters to the drives, or the drives lost initial parameters, and if so how do i give them their parameters back.
Ty for any help given.
Re: Fa10 Wire EDM Alarm S02 INIT PARA ERROR
I have merged what are essentially duplicate threads. Please, one thread per issue. Duplicate threads become especially confusing if they both get replies.
FYI, a better approach than duplicate threads is to make an additional post to the original thread, perhaps with more details. A photograph (or a screenshot) can be very helpful.
Re: Fa10 mit. Wire EDM. Alarm S02 INIT PARAMETAR ERROR
This appears to be posted in the wrong forum. Cincinnati_CNC is primarily for machining cetners/turning centers from Fives Cincinnati (formerly Cincinnati Milacron) or other machines with one of their CNC controls on it. This does not appear to be related to those so would probably get more helpful responses in the correct place.
Based on your post I don't know what control or drives you have so this may not be relevant, but E7 is frequently an E-stop indicator and F1/F2 designate axis number on the drive.
- You may not post replies
- You may not edit your posts
Forum Rules
