- 750 sabre y axis play
hiya guys, im new to cnc milling and purchased a old 750. it seems to have a bunch of play in the y axis and assume it needs a "ball screw" i think its called. is there a guide or any advice floating around on this topic.
ive been told something can be reconditioned if i send it off but would like to have a go at changing the part myself.
Re: 750 sabre y axis play
Before replacing (or reconditioning) the ballscrew you want to identify whether the "looseness" is actually in the ballscrew or the support bearings (or possibly the coupling). If you are new to machining, I'm assuming your tolerances won't be extremely tight so a little wear in the ballscrew may be acceptable (at least short term). You can isolate the various components to determine how much of the backlash is in the ballscrew versus the bearings. Greg Wood just posted this procedure in another thread a couple weeks ago (see thread labelled "New Cinci Arrow 500 Problem")
i ended up getting a engineer out, it transpired that the coupling had come loose when the machine had been transported to me. it was all fixed in an hour or two.
- You may not post replies
- You may not edit your posts
Forum Rules
