Originally Posted by
gwood
See if this will help. The Dallas Realtime Chip held the User Settings and the VFS5 Drive Program. You may need to have this drive serviced
by someone like Kilroy of Fives-Hebron who has the correct files to load onto a new module after cleaning and servicing the drive.
Replacing old capacitors, etc...
Thank you sir! that was some more good info on there.
I've combined that information in addition to the spindle addendum and have built a TL file. The spindle/vfs unit accepts the TL without error (after many attempts for different values.)
After successfully transmitting the TL file upon 'EN' command or 'enable' button in motionlink I receive an ERR 18 bad TL file.
It looks like most/all variables have bad values stored in the VFS5 unit. I'm able to load/change seemingly all of them but I clearly don't have all the config values. a `DUMP` returns that the unit is locked (as expected)
I have requests out to fives & Kilroy for load/service - waiting to hear back there.
Different than others where the values seem to not stay - once I set one of the parameters/variables they persist over power cycles and no power times (at least over the last week of debugging)
attached screenshot shows some of the values on the drive before changing them.
Original TL file that came of the the spindle
Code:
;TL VFS5 v1.0.3bC
MOTOR = Q%wr=510±?2;"û6»"»3»c»&÷B¿rû"ÿvû&•cÿÿcŸrÿbÿ2»6¸¿s»#Ù#uÿ3³sÿ]U]gwuwUYEWTXwõU]¹C0ùQ
AMPS = 55
VOLTS = 759
;UNITS:
INUM = 1679098879
IDEN = 3211381
VNUM = 1612001239
VDEN = 1880162355
;TUNING VARIABLES:
KP = -14383
KPROP = 4765
KV = 18201
KVI = 1017
LPF = 1
LPFHZ = 629
;PROTECTED VARIABLES:
AMPS = 55
ANGLD = 4115
BSLIP = 10067
FOLDD = -19973
FOLDR = 1617
FOLDT = 305
IBASE = 43
ICONT = 3
IMAX = 8
IND = 1
IZERO = 2
MADV = 0
MANG = 189
MSLIP = 0
POLES = 4881
RDRES = 4
SGOOSE = 4
SLOPE = 5115
VADVTBL = 121929474
VBASE = 1033997546
VMAX = 1306118496
VOLTS = 759
ERR 208 'C12' INTERNAL
cobbled together TL file that loads successfully
Code:
;TL VFS5 v1.0.3bC
MOTOR = V-2604A
AMPS = 55
VOLTS = 230
;UNITS:
;PNUM = 1;err 59 not w/rotary
;PDEN = 1;err 59 not w/rotary
VNUM = 44739
VDEN = 10
ANUM = 4474
ADEN = 1000
INUM = 4095
IDEN = 100
PXNUM = 1
PXDEN = 1
VXNUM = 131070
VXDEN = 10
;TUNING VARIABLES:
ABAUD = 0
ACC = 100000
BAUD = 9600
CAP = 0
CAPDIR = 1
CLAMP = 0
DEC = 4500
DEP = 0
DIR = 1
DTIMER = 15000
ECHO = 1
EXTDX = 0
EXTLOOP = 0
FAULT = 0
GATEMODE = 0
GEAR = 0
GEARI = 4096
GEARIC = 2048
GEARIO = 4096
GEARO = 12000
GEAROC = 27000
GEAROO = 12000
GIMAGF = 7735
;ILIM = 100 ; err 84 out of bounds
IMAG = 18
KC = 200
KP = 2000
KPROP = 5000
KV = 7705
KVI = 2500
LOAD = 1
LPF = 1
LPFHZ = 100
MONITOR = 0
MORNT = 4
MSG = 1
MTIMER = 120000
MULTI = 1
PECLAMP = 100
PEMAX = 32767
PEXT = 0
PFB = 0
PL = 0
PLIM = 0
PMAX = 2000000000
PMIN = 2000000000
;PORNT = 0 ;err 59 not w/rotary
PROMPT = 1
PROP = 0
;PROTARY = 409600000 ;err 59 not w/rotary
RAMP = 1
REG = 0
REGKHZ = 1000
ROTARY = 1
SCKSUM = 0
SCRV = 1
SLIPLIM = 55555555
SS = 0
STATMODE = 0
TQ = 0
TRC = 0
TROTOR = 75
VDEFAULT = 200
VOFF = 0
VORNT = 500
VOSPD = 11000
VUP = 15
VUPH = 15
VXAVGS = 1
VXDENC = 1111
VXDENO = 10
VXNUMC = 65535000
VXNUMO = 131070
VZR = 5
WATCH = 0
WTIME = 1000
ZERO = 0
AMPS = 55
ANGLD = 0
BSLIP = 7650
FOLDD = 100
FOLDR = 900
FOLDT = 200
IBASE = 98
ICONT = 45
IMAX = 67
IND = 1
IZERO = 25
MADV = 0
MANG = 165
MSLIP = 0
POLES = 512
SGOOSE = 0
SLOPE = 41
VADVTBL = 12500
VBASE = 1500
VMAX = 12000
VOLTS = 230
