- Message "Autorization Required" help, how quit this?
Need more info to try and help you. Your title is about authorization required, your question seems to be about Profibus.
I dont see any attachments so cant refer to them.
The Profibus question has already been asked and answered...how many and where they are located depends on your exact config, but essentially only the terminating connectors should be "ON", the rest are off.
Authorization required...this is typically from people swapping components between machines. It basically says the serial number on hard drive does not match serial number of control. If you haven't swapped components, it is possible the Serial number chip is not connected properly.
- You may not post replies
- You may not edit your posts
Forum Rules
