Need Help! Spindax sc 1000 parameter.
Results 1 to 4 of 4
Thread: Spindax sc 1000 parameter.
    Sep 2017
    Finland
    Default Spindax sc 1000 parameter.
    Hello from Finlandia.
    My spindle drive have OC alarm ( over current). When i put enable on.
    (the machine worked well, but we moved it other garage( Bad thing ). now spindle not work.)
    I measured motor insulation , coil ohm, resolver etc. all ok.
    My resolver was out of the machine.. must i do resolver phasing?
    Spindle Motor is 5,5kw control techniques
    magnetising current 14A
    slip 50 rpm. 270v /18.5A
    Can anybody help me to check corrent parameters my spindax drive.
    now there is..
    pr 7 = 4
    pr9 = 100
    pr13= 50
    pr 28 = 35 magnetising current
    pr 45 = 47
    regards
    Ahonen VM
    Default Re: Spindax sc 1000 parameter.
    Did you get sorted as those are the normal settings
    Quote Originally Posted by AhWe View Post
    now there is..
    pr 7 = 4
    pr9 = 100
    pr13= 50
    pr 45 = 47
    regards
    Ahonen VM
    Mar 2008
    Ahonen, Robert Varney is one of the the only people I know that could help you with this CT Control with Spindax Drive on an Arrow.
    Contact Fives-Cincinnati and ask for him, he may be able to help you (8595344750) 8am-4:30pm EST USA
    Ahonen, the resolver has to be setup correctly if you have removed it and not re installed correctly. Have you got equal voltage on all 3 phases.
