CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831
Results 1 to 2 of 2
Thread: CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831
    Jul 2005
    ECUADOR
    Default CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831
    Hello
    Please some help.
    I have a Cincinnati Arrow 2 with Acramatic 2100 - and Siemens Simodrive 611 drivers.
    Yesterday the machine was Ok, today the machine can`t work, the servo driver X,Z has the error E A831 and the light is red on the profibus expansion card (Profibus - DP), the other 2 profibus expansion cards are ok, they have green light.
    I swapped the profibus expansion cards with the Y driver. The same defective profibus expansion card is giving an error on the Y driver and the XY driver is ok (RUN) have green light on the Profibus - DP. I turn the machine ON and it didn't give an error, but the tool drum started to rotate.
    I am going to purchase a Profibus expansion card to replace the defective. My concerns is if the Profibus expansion card (Profibus - DP) has to be configured or it will just wok without any configuration.
    Please some advise
    Attached Thumbnails Attached Thumbnails CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831-20220512_153836-jpg   CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831-20220512_110540-0-jpg   CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831-20220512_110521-jpg   CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831-20220512_115248-jpg
    CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831-20220512_115234-jpg
    Mar 2011
    Default Re: CINCINNATI ARROW 2 - PROFIBUS PROBLEM - E A831
    Replacing the card is easy, but there are a number of things that can cause that alarm. If you swapped the cards without chamging anything else, and the problem moved with the card that is fairly conclusive.
